Static noise when pressing keys
By ndy4eva · Jan 21, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,823 views
Posted Jan 21, 2010 · 19:35 UTC#1
I tried out U310BT unit on my Jag last night. Everything seem to work fine. I used harness kit, and antenna kit for the wirings. I was pretty impressed with Pioneer sound quality compare to the factory radio. :D
One thing that bothered me. Whenever I press hard key or touch-screen key, I hear the noise from the speakers. When there's music playing (mp3, cd or radio), it's very hard to notice. But when it isn't, you can hear the static noise. I did hard-wire by-pass for hand-brake. Would it create the noise? possible grounding issue? I guess I could disconnect hand-brake wire but I don't want to re-solder it later.
Any thoughts or suggestions?
Posted Jan 25, 2010 · 06:01 UTC#2
I tried without parking brake bypass. The static noise is still there. I think I might have faulty unit. Uhmmm... I think I will drop by the store ask for replacement.
Posted Jan 25, 2010 · 06:41 UTC#3
Does your vehicle have a factory installed power amp?
Posted Jan 25, 2010 · 07:51 UTC#4
Nope.. The noise comes after the button release for about 1-2 seconds.
Posted Jan 25, 2010 · 17:16 UTC#5
The only two things I can think of off-hand are bad wiring or a hardware problem. Once you've double-checked the wiring, bringing it back to the store for an exchange is the way I would go.
