I've read a few threads here that describe my problem, but I haven't seen anything definitive about whether this is a factory repair problem or an installation/configuration problem. I installed my Z110BT (+ correct bypass) this week. All functions work except opening/tilting the screen.
Like other users, I can see the "Open" and "Insert SD" buttons. They light up when I press the buttons, but the unit doesn't move. No beep/boop sounds or sounds from a drive motor either. The tilt buttons are inactive and can't be pressed at all.
Does anyone know what causes this? Is a replacement unit the only option? Can anyone confirm that there is no setting or installation trick that will make this work?
Thanks for any help. This is a great forum.
