Speed camera warning available in EU
By ikon66 · Jan 23, 2010in General💬 20 posts👁️ 5,559 views
Posted Jan 23, 2010 · 22:48 UTC#2
This looks to be a pre configured AVIC FEEDS POI file which anyone can do on there own with the application. The F10/Z110 does not support any type of POI warning system so this will only allow you to display them on the map but will not alert you on your approach. I actually use this ability now with my unit. However, I did request a POI alert feature be submitted to the Z110BT as a feature request for a new firmware if there is one. Lets hope it happens. If you are able to get an actual warning on the screen as you approach a traffic cam please let us know. However without a firmware update to the unit I don't see how this is possible.
Posted Jan 23, 2010 · 23:10 UTC#3
I have installed it and the unit beeps 3 times when you are aproaching speed cameras
Posted Jan 23, 2010 · 23:33 UTC#4
Very interesting and I am glad to here that. Can you tell me what format the files are in and what method did you add them to the unit?
Posted Jan 23, 2010 · 23:45 UTC#5
not sure of the file format or technicalities, however, you register, download a program, poibase, select what unit you have, you need a SD card with 16mb of memory available.
Poibase downloads the data to the card, put the card in the F10, turn on, it uploadeds the data, in the settings you have to activate "blackspot" notification.
as you approach a speed or saftey camera you can see the icon and about 100 yards before you get to it it beeps 3 times, too loud for my liking so will need to investigate that.
this is their website
http://www.poibase.com/de/was_ist_poibase/?L=2
hope that helps
Paul
Posted Jan 23, 2010 · 23:49 UTC#6
In what area of the settings screen is this "blackspot" setting in the F10
Posted Jan 23, 2010 · 23:53 UTC#7
from the instructions:
To display the safety cameras on your:
AVIC-F10BT: Select Menu -->; Settings -->; Navi Settings -->; Black Spot Settings -->; Black Spot Settings [On].
AVIC-F310BT: Select Menu -->; Settings -->; [>;] -->; Black Spot -->; Black Spot [On]
Posted Jan 23, 2010 · 23:58 UTC#8
Hmm, no such setting on the Z. I will be contacting the person I spoke to yesterday at Pioneer about this. I just put that very feature in as a feature request in a future update.
Posted Jan 29, 2010 · 20:48 UTC#9
Hi VBlue42,
Have you got any update on this "blackspot" notification? This is also the top one on my wishlist... Thanks!
Posted Jan 29, 2010 · 20:55 UTC#10
That option is not on the Z. Hopefully, POI alert will be added in a future update of the unit. I have requested it be added as such. FYI, you can still have traffic camera POI on the unit buy using AVIC FEEDS. It wont alert you but they can be displayed on the map for reference as you approach their locations. I have them on mine. I will post the files if people want them.
Posted Jan 29, 2010 · 21:12 UTC#11
I have a few more questions: Is it true that the POIs in each file cannot be >100? If so, we need to break them up into <100 each, right? Also, how many POI files can z110BT accept?
BTW, I can't seem to find a way to search custom POIs in z110BT. Is there a way to do it?
Posted Jan 29, 2010 · 21:23 UTC#12
Yes.
100
Unfortunately there is no search option for AVIC FEEDS POI. I have also requested this be fixed in a future update.
Posted Jan 29, 2010 · 21:27 UTC#13
Thanks again for the quick response!
Posted Jan 30, 2010 · 09:49 UTC#14
On the HD3 (more or less the same as Z1/Z2/Z3), it works more or less the same. You only get the separate "blackspot" menu items once you download the software/POIs for the speedcamera's.
I would assume it works the same for the Z110, so you will probably only get that menu item once it's installed....
Posted Jan 30, 2010 · 18:26 UTC#15
I tried it and I could not get the software to do anything as I am in the US and it is probably region specific. I doubt that setting is hidden in the Z anyway.
Posted Jan 30, 2010 · 21:02 UTC#16
Possibly. However, just for info, you can see how it works on the HD3 / Z3 here:
http://home.planet.nl/~jwq/temp_pioneer/kamera/user_manual_speed_camera_plus_uk.pdf
Note specifically page 4, where it covers the new menu items that appear after installation....
Posted Jan 30, 2010 · 21:12 UTC#17
If there was a way to have the app be able to choose the traffic camera files that I have it may work. That would at least allow me to verify if this hidden settings exist on the Z.
Posted Jan 30, 2010 · 23:56 UTC#18
Something tells me that Pioneer's legal team shot this down in the US. :wink:
Posted Jun 23, 2010 · 03:50 UTC#19
Hey vblue I would like the files if you don't mind. Plus would you know how to change the steering control from mode to vr on the steering control PAC-swi, and was it difficult to install the pac wireless controller to the PAC-swi. Sorry about all the request.
Posted Jun 23, 2010 · 04:17 UTC#20
PM me your email address and I will try to email them to you. If you want to control VR from you PAC module you have to have version 1.6.8. If you do have 1.6.8 it will need to be programed to support VR. Details on how to program it are in the install manual that came with your module. Installing the wireless module to the SWI is very simple.
