AVIC-F700BT Promblem's Please Help
By overkill1028 · Jan 24, 2010in General💬 5 posts👁️ 1,384 views
Posted Jan 24, 2010 · 08:20 UTC#1
So I just bought the 700BT and its really messing up...
Reboots every 3 mins
The starting up display on the botton never goes away
when u press map or GPS it frezees and needs to be reset.
So i thought well its NEVER been updated and ill see if that fixes the promblem and when i go to update it i get this every time at the same spot it updated a Serena?? im guessing its a file for the TTS
If anyone knows why or how to fix please help me out thank you
Posted Feb 02, 2010 · 16:03 UTC#2
Well, isnt it possible the SD card you are using is bad ? Also i am not sure if it will fix your unit..
I think you should turn off all or most features on you system and then enable them one by one.
Like drive around for 10 minutes without anything, you main menu. If working : drive around for 10 minutes with navigation on. them music etc etc.
Posted Feb 25, 2010 · 02:10 UTC#3
ive got the same issue, only stops at vf_nana...., but it's at 44% like yours. Did you have any luck with this
Posted Apr 05, 2011 · 06:09 UTC#4
Same here! Help!
Posted Apr 05, 2011 · 14:55 UTC#5
did any of you try to redownload the update, maybe you got a corrupted file during the transfer
