Help, how can I use Igo 8.3 instead of Igo8 ?
By gusztim · Jan 26, 2010in Hacks/Mods💬 9 posts👁️ 3,653 views
Posted Jan 26, 2010 · 15:28 UTC#1
Help needed.
I have an f900bt with 3,01fw and map v2,00. I was looking for newer maps and tried to upload them but did not work. All I got was empty countries. If anyone could help how to upgrade to Igo 8,3 or use the new maps on my system, would be appreciated.
Posted Jan 26, 2010 · 16:02 UTC#2
Hi,
AVIC with firmware <3.0 run Igo 8.0. AVIC with firmware 3.0 and newer run Igo 8.3
To use newest maps you need hacked ezrider.exe and generic worldwide licence.
Posted Jan 26, 2010 · 16:10 UTC#3
Hi,
I've tried with hacked ezrider and generic worldwide license, with I've found, but has not work. I couldn't start the map function, it said "system is loading, please wait" for 5 minutes, then I switched off.
Maybe I did not work correctly.
Posted Jan 26, 2010 · 16:44 UTC#4
Try to start ezrider from the testmode and see if it has any errors.
Did you install any mods ?
Try to delete user files ("My Flash Disk\USER\UserData\iGo\save").
Posted Jan 26, 2010 · 16:52 UTC#5
Good point, I didn't know I can run anything in test mode. I'll try it and delete user files.
Posted Jan 26, 2010 · 20:38 UTC#6
So, I tried to run the ezrider.exe, and finally I got an error message: "Parse error [ expected]"
Anyone could help what to do?
Posted Jan 26, 2010 · 20:39 UTC#7
Hi,
Make sure you add the licenses to the ones that are already there. Do not remove the original ones.
Posted Jan 26, 2010 · 21:37 UTC#8
I did. The problem was not that. Finally I solved, I had to copy all the files where the ezrider was.
Thanks for the help.
Posted Feb 09, 2011 · 20:42 UTC#9
Here is the Cracked exrider 3 again mirrored including something everybothie searches ;) general .......
http://www.multiupload.com/QC89FVHKY0 use the first button : Direct download that one is the fastest
Can;t i put maps on the SD and run it from there. If yes in witch folder do i have to put them?? Thx
Edited Feb 09, 2011 by Jackieboy
