P20 HD Tuner + MSN Direct = Need Splitter?
By tombonneau · Jan 27, 2010in General💬 16 posts👁️ 2,105 views
Posted Jan 27, 2010 · 07:19 UTC#1
So I'm debating getting the P20 HD Tuner for my Z110 (installing it this weekend). But I'm reading up on things and it sounds like I might need a splitter if I also have MSN Direct connected (which I will).
Or will I be fine with the HD tuner and MSN together, as long I just tune into any AM/FM stations via the HD tuner?
Posted Jan 27, 2010 · 07:50 UTC#2
Nope, no splitter
Posted Jan 27, 2010 · 15:28 UTC#3
Ok, thanks. It wasn't very clear to me. Do you have the HD tuner? Is it worth getting? I'm fine with the whole no preset channel name issue, but is the sound quality that much more noticeable? I'd really only use it in the morning for sports talk radio and maybe a few FM station now and then.
Posted Jan 28, 2010 · 04:41 UTC#4
I believe you will have to put the MSN Direct tuner in between the HD radio module, and the head unit.
Posted Jan 28, 2010 · 15:51 UTC#5
So just ordered this unit .. hopefully HD radio in LA is worth it.
Anyway, just want to confirm that I won't need this splitter:
http://www.amazon.com/gp/product/B0002E ... _sim_01_01
Is the point of using a splitter so that the FM & AM buttons aren't "grayed" out and you can still control them directly vs. having to indirectly access them via the "HD Radio" section? I've been reading up for days on this and none of it seems very clear.
Posted Jan 28, 2010 · 17:24 UTC#6
The F-series needs a splitter because the MSN is built-in. The Z will grey out the AM/FM buttons when you plug in the HD tuner but has a pass through so you do not need a splitter.
Posted Jan 28, 2010 · 17:55 UTC#7
Thanks, Cameltowing (awesome avatar btw).
I'm not quite sure I understand what pass through means, but sounds like my installer should know what is what and hopefully won't have any problems.
Posted Jan 29, 2010 · 21:03 UTC#8
I think you have an ugly ass toe. :lol:
Posted Jan 30, 2010 · 02:42 UTC#9
Not my toe thank god. I would imagine that tattoo hurt like crazy though
Posted Jan 30, 2010 · 03:36 UTC#10
:lol::lol::lol::lol:
Posted Feb 14, 2010 · 06:05 UTC#11
So just did my install tonight, and the antenna does not seem to be working properly with the HD. The installer wasn't quite sure why, I'm gonna bring it back next weekend. He thought maybe the antenna wasn't connected properly? Some stations come in, not a lot, and it clearly doesn't seem to be picking up any HD signals (as shown in the HD Radio video that someone posted on here, it isn't doing any of that moving from analog to digital or vice versa).
Anyway, that got me thinking to this thread and what I'd read, and are we 100% positive that I won't need a splitter to get it all working correctly?
Thanks.
BTW, unit is pretty tight. What's maybe most impressive is how quick the audio is to play when you switch source. Going from iPod to CD is as quick is turning a radio dial. Even quicker actually. :)
Posted Feb 15, 2010 · 05:41 UTC#12
Nope, you don't need a splitter. Have you gone into the settings and turned on the HD selection? It may just be set to analog. But if you're not getting good reception that could be your issue, HD requires a stronger signal.
Posted Feb 15, 2010 · 05:58 UTC#13
According to the manuals for the MSN tuner and HD tuner, both require the tuners to receive an input from the car antenna, which they would then route into the Pio HU. Based on this, I would think I need a splitter from the car antenna to connect to the MSN tuner and the HD tuner.
Pretty sure the HD settings are all set, but I'll check tomorrow morning. I would def. get HD signals as I live in LA.
Posted Feb 15, 2010 · 06:03 UTC#14
The MSN tuner has an "in" and an "out" connector for the antenna leads, no need for a splitter.....
Posted Feb 15, 2010 · 11:36 UTC#15
What he said, and what I said before. You don't need a splitter because there is no reason for the actual head unit to receive an antenna signal because it wont use it anyway. In and out of the MSN box into the HD20, thats it.
The AM/FM in your head unit will be greyed out....you will get them through the HD source on your deck
Posted Feb 15, 2010 · 15:54 UTC#16
Ok, so in effect the antenna signal will just pass through the MSN box and then into the HD20. I'm sure they ran the antenna into the MSN and then into the HU and just bypassed the HD20. This (hopefully) helped a lot. Thanks, guys.
