MY avic z2 seems to be draining my battery
By MIGGERNAUGHT · Jan 28, 2010in General💬 11 posts👁️ 1,365 views
Posted Jan 28, 2010 · 18:22 UTC#1
so this is kinda weird, i bought a new car and moved all my shit over to it, including backup cam, ipod connector, and xm with nav traffic.
any ideas for what wires I should check to see what might be causing a drain? its been so long i dont remember what all the wires do now unfortunatly.
I also have Garret's upgrade from a year ago on my had and i love it you should all get it.
Posted Jan 28, 2010 · 18:33 UTC#2
Yellow and Red are power wires. Does the unit shut off when you turn off the ignition key? Do you have a backup camera?
Posted Jan 28, 2010 · 22:32 UTC#3
Yeah i have a backup camera, and when i shut off the ignition the head unit does shut off. I am willing to install a switch somewhere but I dont want to be losing my settings every time I flip it on..
Posted Jan 29, 2010 · 06:03 UTC#4
How do you know... or rather, what makes you think your headunit is the culprit?
Posted Jan 30, 2010 · 21:57 UTC#5
I just had the battery replaced and the dealer said it was the culprit. I believe it since i had the same problem with the last car i took the deck out of.
Posted Feb 04, 2010 · 18:10 UTC#6
any idea which wire i could put a inline switch on but still save settings? is that possible?
Posted Feb 04, 2010 · 19:08 UTC#7
I honestly don't have an answer for you. :( I'm not knowledgeable enough on this to give you an answer that will get you anywhere. There are a LOT of smart people on this forum though so I'm sure someone will be able to help you with this. :)
Posted Feb 08, 2010 · 18:35 UTC#8
i figured it out! the backup cam for some reason had the accessory and power leads on the same one. I dont know why I did that when I installed it. but the draw dropped from .3333 amps to .0900 amps so i think we are good now
Posted Feb 08, 2010 · 21:44 UTC#9
Nicely done!
Do you think you had it that way on the old car too and just did it the same?
Posted Feb 08, 2010 · 23:29 UTC#10
That is the reason that I was asking if you had the backup camera installed... Glad you found the problem!!
Posted Feb 24, 2010 · 04:52 UTC#11
I am having the same problem as you - same accessories too.
I'm just a little confused from your post and wanted to double check - "the backup cam for some reason had the accessory and power leads on the same one" are you saying that when you installed it you connected the backup-cameras accs and power wire to the same wire on your car? And to fix it you just rewired it so one went to a constant 12v+, and the other to an ign/accessory wire?
