So it is best to just replace the stock amp with aftermarket amp. Do I need to look for an amp that has a 2 ohm output? What about the speakers in the front. Do they have amps on them or can I wire them directly to the Z1? Which wire harness is preferred? I hear the VW wire harness is what most installers are using. When I pull out the oem stock unit, connect the vw harness to the existing harness in back of the unit. Then I take the wire ends of the vw harness and connect to the Z1 such as power, ground, remote. Am I understanding this correct?
Questions:
If I did not replace the Bose amp with an aftermarket amp, will the Z1 with the VW harness give me sound for my front speakers? I know the subs will not work unless I replace the bose amp, but what about the front speakers. Are the front speakers controlled by the connection in the front vw wire harness or they TOO like the subs controlled by the Bose Amp? If so where is the Bose amp in a 2002 Clk 430?
When I replace the oem head unit with Avic Z1, what will my digital dash display say when I play music?
Sorry for so many questions, but UPS online says that my unit should be here today.
