Hi,
Just had my z110bt installed. When I shut off the car, the deck stays on. I have to start up the car again and then shut down...at this point the deck powers off.
Any suggestion as to what the problem may be.
Thanks,
Nadeem
Hi,
Thanks,
Nadeem
Either your car has a feature that retains power to the unit when the car is turned off or there is an install error.
Thanks for the reply!
I noticed that if I am listening to a CD and power off...the unit shuts off. If I don't have a CD in, it will not shut off. I have a 2006 Honda Odyssey minivan.
Nadeem
06 Odyssey should have both a constant and a accessory wire on the wiring harness so it should shut down when the car is shut off completely or when a door opens. I just installed a deck in an 03 Odyssey I believe it was that share the same harness as your 06 Odyssey. I quickly just shut the car down and it turned off. Possibly an installer error or defective unit. Did you have factory navigation?
