Please Help AvicF700BT not turning on
By DSG04Lightning · Feb 01, 2010in Problems/Troubleshooting💬 17 posts👁️ 9,451 views
Posted Feb 01, 2010 · 20:32 UTC#1
Hey Guys Thanks in advance for any help
Ive had my Avic F700 for about a year an a half now, i started up my vehicle the other day and the menu/map button lights up with no splash screen, after like 30 seconds the lights go off on the menu/map buttons and still blank screen it seems like the unit is dead after i push the reset button it does the same problem stated above.
any help is appricated
Posted Feb 01, 2010 · 20:35 UTC#2
wanted to subscribe
Posted Feb 04, 2010 · 19:29 UTC#3
anyone? it just suddenly stopped working, ive checked all the fuses and wiring
Posted Feb 05, 2010 · 10:58 UTC#4
Have you tried getting into service mode ?
Posted Feb 09, 2010 · 02:52 UTC#5
LOL i actually just started having this problem this morning.
same exact problem but f90bt.
subscribe for an answer!!!!
Posted Feb 09, 2010 · 22:23 UTC#6
so i disconnected my battery for a few minutes, when i reconnected it the radio works again.
it is still acting ODD though.
after the splash screen i have to wait a few seconds then hit "map" for anything to show up :?
edit: nevermind. worked 2 times now back to broken
Posted Feb 11, 2010 · 16:44 UTC#7
My unit seems to have a similar problem. Hitting reset will bring allow the unit to boot and run for maybe a minute sometimes, other times I’m just left with a black screen. The fan is always running, so I don’t think it’s a wiring issue. I can boot into test mode or the wince flash update screen, in either mode the unit will power off before I can do anything, usually about a minute. Any ideas?
Posted Feb 12, 2010 · 07:24 UTC#8
The exact same thing just happend to me today. I went into a store and when I came out after the boot screen everything went black but the units fan continued to run. Hopefully someone will have the fix
Posted Feb 12, 2010 · 22:28 UTC#9
Same issue...started this week (2/8/2010) for me!
Posted Feb 17, 2010 · 14:32 UTC#10
If upgrading/reloading the firmware with a format and a fresh copy of the maps (See either of the two 3.0 update threads in the hacks/mods section) doesn't work give the following thread a try:
viewtopic.php?f=33&t=25465 (This thread helped me get a "bricked" unit up and running again)
Posted Feb 20, 2010 · 22:54 UTC#11
I have a F500BT that was having a similar problem. I now think I know what the problem is but I don't know how to solve it. The problem on my unit was that it wasn't powering OFF. As a result the battery drained and the unit won't operate correctly or at all. I charged the battery in the house and brought the unit back to the car. It worked fine EXCEPT (and here us what I need help on) when I have a USB flash drive installed as a music source and turn off the ignition an error screen comes on probably because a USB device won't work w/o external power. The manual says the error message might be because the USB cable is shorted, but the device was working perfectly before I turned off the key. The unit is frozen with the error message on the screen. I have to power down the unit with its power button to get it to turn off and stop draining the battery. PS When I dont have the USB cable plugged in, the unit powers down correctly when the ignition is turned off. Does this problem ring a bell with anyone?
Posted Mar 02, 2010 · 21:17 UTC#12
Same exact thing happened to me after I had to have a dead battery replaced. It did not happen right after the battery was replaced. It happened two days later unexpectedly. Menu and map leds come on (very low) and I can hear the fan and perhaps the cd mechanism. No screen no power. Leds then go off and then nothing. If I reset the same thing happens over again. Took it in to place I had it installed and they could not figure it out. Fuses were all good. Its going in for repair.
I thought I was going crazy until I read all of the postings with the same exact issue. Mine also happened exactly one year after I had it installed. I gave up a long time ago trying to get answers from Pioneer. I am willing to present all of our posts to see if it will stir up something at Pioneer Technical. All of us cannot be crazy.
Posted Mar 13, 2010 · 21:27 UTC#13
im going to try to update and see if that helps
Posted Apr 13, 2010 · 13:17 UTC#14
Well i attempted to update and the writing part stopped at 6%. After like 4 tries i just sent the unit into Pioneer for repair. Estimate came back at $390.
Posted Apr 15, 2010 · 13:11 UTC#15
F-90BT, same issue just started today. I took it in for an oil change, and when I started it up, radio came on fine. About 1 minute later the unit reset, and the splash screen came up for about 20 seconds before the whole unit went dead. So far no resolution, but I'll post as soon as I find anything.
Posted Apr 16, 2010 · 16:53 UTC#16
good luck man, hopefully you dont have the same situation i was in. I asked the tech when i called they said they had to replace a part that was pretty much the same as "they are giving me a new unit" all i know when im faced with the decision on another car sterio or home i will not be going the same route!!
Posted Mar 02, 2017 · 22:50 UTC#17
I am still getting this error with my F900BT. Started with it working then all of a sudden while driving it would reboot. Then the rebooting would repeat and eventually just stop rebooting. Now it won't even load at start. It powers up, the lights are on, the fan is whirring but no screen. I can't even get into any service mode or update the files. Sometimes when it went to reboot it would distort the image on the screen before rebooting. I have found no answers and now I'm looking to just replace if I can't figure it out. HELP!
