I have to say thanks for this.
I have an european AVIC F710BT and I ... Brik'd It ... then saved it thanks to the usb testmode.
What I did:
Following the guide for the 900 posted here:http://avic411.com/forum/viewtopic.php?f=34&t=30637&p=207335&hilit=spr_Compass#p207335 , I tried the hack for quick delete route, and did a few other modifications for I expected them to skip the Safety Warning message.
But, I either did a mistake at some step, either the mod is not compatible with AVIC F710BT with my firmware 3.020200.
Then it was quite a mess:
> no navigation
> System loading waiting message for 5 minutes then reboot (that sucks)
> Little windows CE windows for one second saying "database not found" or something like that
> No SD card support (not detected for music, tesmode don't work anymore on the SD Card
> No Usb support (detected but empty when searching for music or vids)
> No tel support
I however still had access to config and FM radio ..
I first tried to boot on testmode from the SD CARD > Failed
I then tried to update firmware with pionner downloaded stuff , either with USB or SD > Failed
I tried to reset and retry testmode and update> Failed
I tried to reset to factory setting and retry testmode and update > Failed
At that point I was stuck with a brick'd, non-functionnal / half functionnal Nav system.
However I found out your post and gave a try to testmode from USB , I could access winCE and solve the shit.
Wanted to post about it just in case it happen's to someone. Hoping this solution will be a good workaround for them also
