Is connecting the VSS wire absolutely required on the AVIC X710BT navigation unit?
What are the side effects of not connecting this wire, if I can't find the VSS wire location in my car, or don't want to connect to it?
thanks!
thanks!
thanks!
I don't think the 710 has a Vss connection.....
the X710 does not have VSS, the X910 does.
Sorry, looks like you are all correct -- I had been looking at a PDF install manual that covered both units, and it was mentioned there.
What about the REVERSE GEAR SIGNAL INPUT (purple) wire? Can this be left disconnected if I don't want to connect it in my vehicle, or should it be grounded permanently?
I have already moved the mute wire, and will be grounding it along with the parking brake wire, but just want to make sure I don't miss anything else here.
thanks!
