Hi,
I recently purchased an F500BT with ND-G500 amp, and it's suddenly dawned on me that this isn't going to be a simple job!
I've spent the last week looking around the internet and checking out various options, and now I kind of understand what needs to be done, I'm still a bit confused.
Is there anyone out there who has successfully installed an F500BT with ND-G500 into a car with a Bose amplified system, who would be willing to share their configuration?! I like to think I'm a competent person, but just need guidance around particular relays etc. (if required).
I've read about using Parrot kits to reduce the output of the ND-G500 to line-level ready for the Bose amp - will I need to modify the harness in anyway, or can I simply use the ISO connectors on the Parrot kit and leave the connector for the Parrot device unused? Also, do I need to amplify the signal coming from the headunit, as the ND-G500 will be expecting a higher signal than the headunit preamp outputs will be sending?
I also believe there is a problem with sending a mute signal, as the ND-G500 doesn't send an mute signal that can be used with a Bose system...
I have a 2005 Mazda 6 Sport. So far the leads I have looked at include SOT-077 (standard SOT, non Bose), 10-400 & 10-211. I am based in the UK, so I'm not sure if these codes are global, or specific to the UK.
Any help or guidance that anyone can offer would be grately appreciated!
Cheers in advance.
