hi i was wondering which wire to power the z1 cuz i want to test the z1 if its working or not dont wanna fry the z1 when testing which wire to power it up.
how to power z1 to a battary
Yellow and red go to positive and black goes to negative.
Thanks worked like a charm but one thing is that is my z1 broken? I pressed my tilt button and it slid down n i pushed a cd in the cd drive then i press tilt again it didnt go back up i tried pressing all the button but nothing will make it go back or give back the cd to me.
any 1 know how to get the cd out?
When you press the button to eject the CD, do you hear a motor whirring like it's trying to eject it?
If not you might have a broken unit.
the eject button the screen or the cd button i pressed both nothing happened. can i fix it myself or i gotta sent it to pioneer and give them 200? =(
any help?
If it's working correctly, you don't need to push the tilt (actually open/close) button after putting in a CD, it will close automatically... Are you sure the cd went in correctly ?
um i i gotta press the cd in dont know if its the right way and then it didnt tilt up by it self. my lil bro say when he helped me brought the z1 the previous owner tilted the screeen and the screen came up now that i tried to test it for a few month cuz its sitting in my room and got all my stuff to put it it dont tilt. maybe the cd is jammed?
any1 i really dont wanna waste 200 buck just to repair my nav. ![]()
any 1?
You either need to repair it yourself or get it repaired. It's toast.
i dont know whats wrong tho any way to get the cd out?
any help?
There is a gear on the bottom of the unit that you can turn to force the screen to go down, from there you can fish the disc out.
oky thanks if i sent it to pioneer will they help me fix everything if they charge me $200? or they gonna charge me more to fix my nav?
I believe it's a $200 flat rate.
I think it's 200 if they DON'T have to replace anything. If they replace something. Like the LCD then I would imagine they would charge you for the lcd and repair.
