connecting a Blackberry to play Pandora
By brian_nyk · Feb 10, 2010in General💬 4 posts👁️ 1,229 views
Posted Feb 10, 2010 · 04:03 UTC#1
Hi, I have Pandora installed on my blackberry Storm and want to be able to play it through my X710 unit. Can I do this by using the 1/8 jack in the front or is there some other way of doing it? Will this interfere with the phone functions when connected via bluetooth? Are there any settings that need to be changed in order to get this to work? I just got the unit and wont be able to get to a warm place to install it until Friday ( Just love the NY winter and the foot of snow we are getting tonight) but wanted to get an idea of what needs to be done before hand. Any thoughts on the subject would be appreciated.
Brian
Posted Feb 10, 2010 · 04:29 UTC#2
Yes, that input is a full AV input. You will need an 1/8 stereo audio cable. Also you will need to set AV2 in the settings of the head unit to VIDEO. You will then select AV2 as your source on the head unit. Open Pandora on the phone and it should play without issue. It shouldn't interfere with the BT from the phone but that depends on the phone, not the unit.
Posted Feb 11, 2010 · 15:16 UTC#3
Great!! Thanks for your help
Posted Mar 22, 2010 · 15:35 UTC#4
yup it works great on my storm (as long as im in a good 3G area, which is next to never)
