Video issue
By itpro2002 · Feb 13, 2010in General💬 14 posts👁️ 2,300 views
Posted Feb 13, 2010 · 03:00 UTC#1
Anyone having video quality issues with z110bt?
I am on second unit with same issue with lines in the screen more visable using cameras backup and front
But can see a little playing DVD
Just upgraded from Z3 and all looked great with that unit
nav was all that was changed out
Ideas??
Posted Feb 13, 2010 · 03:24 UTC#2
Where are you buying your units?
Posted Feb 13, 2010 · 03:49 UTC#3
No doubt... Where are you from?
Are you using a US unit in a non-US country?
This would make all the difference as far as your complaints go...
Posted Feb 13, 2010 · 14:31 UTC#4
I am in georgia and purchase from authorized dist ...Cannot figure out issue just disappointed..I love the unit if I could figure this out..
Posted Feb 16, 2010 · 03:39 UTC#5
do the lines go away when the car is off? do you also have engine noise over audio turn it up and pause a source and take a listen. you may have a dirty power source ,bad grounding,poor connectionsor somthing not hooked up correctly. did you install it? if it was pro done and he made a mistake he might not find it if he is not humble enough to recheck all connections. i do it for a living 25 + years.... jim
Posted Feb 17, 2010 · 01:40 UTC#6
We have exchanged the unit for new one and I have 2 diff types of cameras and both get the lines..Tried a new ground ...Still same issue we have had it out several times moved cables. Still same issue
Posted Feb 17, 2010 · 01:41 UTC#7
And it was professionally installed by the shop i purchased unit from
Posted Feb 17, 2010 · 01:50 UTC#8
What cameras are you using? and where are they located?
I think your installer has ran the video wire along side of a "charged" wire....
I've found that most cheaper cameras have very little protection for this.... It could also come from the video source wire...
For an example, I have this camera mounted about a foot from the electric motor in my golf cart... It use to be worse, but I've since used some 3M alloy tape to help from the electric radiated stuff...blah..blah...
Watch when I apply throttle in reverse... are these the lines you're seeing?
http://www.dawgbonez.com/Videos/dawgbon ... 20Cart.wmv
Posted Feb 17, 2010 · 22:37 UTC#10
hey you still didnt say if you have engine noise on audio or other videos or if it stops with engine not running thanks jim
Posted Feb 17, 2010 · 22:47 UTC#11
From what I know from my golf cart, I could see a Hybrid vehicle causing this type of drama as well...
Posted Feb 18, 2010 · 01:26 UTC#12
does it when car is off as well....I am using a pioneer bc2 backup camera ...and no engine noise...camera is located just above License plate...
Posted Feb 18, 2010 · 01:30 UTC#13
Got any pictures of of the lines you're seeing on the Avic?
I too went from a Z2/3 to a Z110BT....
Posted Feb 18, 2010 · 02:42 UTC#14
I will try and take some pictures
