I have been using my AVIC F700bt for 1 1/2 years. Sometimes while driving it would crash suddenly, but not too often. Anyways, the last 3 weeks a message has been appearing "system startup in progress...please wait". It NEVER goes away. I can't access the map at all. I can only go to AM/FM, but after 1 minute the unit REBOOTS. The process will repeat over and over again. I called Pioneer and they said it's because of the parking brake bypass. They said the software caught up with it. They told me to take the unit out so it has no power, fix the wiring and put it back. I didn't even know the installer bypassed the parking brake. So I took the unit out, and cut the mute wire, and put the unit back in. But it's the same problem. Should I send it to pioneer to fix ($70) ????
What is the correct way of wiring the Mute anyways? I know it has to go in the first pin, but where does the end go? To the parking brake?
