Hi there. I've recently acquired an AVIC-F900BT headunit and have installed it into my car. Both the body and the harness are grounded to the chassis and I am still suffering from the dreaded pre-out speaker Hiss. The noise is only a soft hiss which increases with the volume of the pre-outs. Im pretty sure its also coming from the AVIC speaker outs as well indicating that its not only an RCA problem (I have rear speakers connected to the rear speaker channels of the AVIC amp) I have also run a separate ACC wire directly to the battery for testing to ensure that noise wasn't entering the system from other electrical on the ACC line. Having the engine turned off also makes no difference to the problem. Its not so noticeable when the volume is down low but as soon as i increase the amplification to a reasonable level it becomes a problem, particularly on softer music as its unable to mask the noise
Has anybody experienced anything like this in the past and if so how did you go about rectifying the problem?
Toby
