Crossroads off a little bit
By bit_bucket · Feb 15, 2010in Problems/Troubleshooting💬 5 posts👁️ 928 views
Posted Feb 15, 2010 · 15:20 UTC#1
Just installed the z110bt with vss, and reverse signal. Everything tests good and vss is seen. Unit is still doing 3d calibration. I notice when I go through an intersection that the map dosent show me going through it until after I am physicly through it. So it seems like it is off just a micro amount. Question is does this get better after 3d calibration is complete, or is this just the way it is? I notice there is an adjust my position option but I haven't tried using this yet. Any ideas?
Posted Feb 15, 2010 · 18:48 UTC#2
Its a toss up. It will get better once the calibration is complete but still may be a little off. Position adjustment may help but unit will default back to the original position once you restart it.
Posted Feb 16, 2010 · 01:32 UTC#3
Thanks vblue I appreciate your reply. I don't think the error is great enough for me to worry too much about. I'll just wait until 3d calibration is done. Otherwise it is pretty darn accurate and an overall great unit. Now if only I could figure out why all of my album artwork from my iPhone is all pixelated. I know this can't be normal.
Posted Feb 16, 2010 · 01:40 UTC#4
Yea you really shouldn't be concerned. The unit switches to a close up over view screen when you are approaching a turn that is very accurate to your approach to the turn. The iPhone album art issue has been seen before with the F series. It appears to be only an issue with the iPhone/iPod touch and doesn't seem to affect the other iPod models. Unfortunately the only suggestion I can make is to restore and re-sync your content on the phone to hopefully clear the issue up.
Posted Feb 16, 2010 · 01:46 UTC#5
Again thank you for your reply. This is a great forum!
