Im getting a D2 for my bday in a few weeks. I have a 2004 ford explorer, will it mount directly in the din or do i need some sort of brackets? thanks
Posted Dec 06, 2006 · 02:38 UTC#1
It will fit, you will need a kit. The part number is 95-5026. Though you could remove the bracket from the stock radio and mangle it a bit to fit the avic but it'll look better using that kit.
ok thanks so much! ok on more question, do you know what wiring harness ill need? thanks
You'll need a 70-1771. Also there will be a second plug plugged into the radio. It's probably only going to have a couple wires in it. One of them is gray with a black stripe. That's your vss wire.
