Unable to Copy files in testmode (firmware 2.0)
By shleppy · Feb 18, 2010in Problems/Troubleshooting💬 2 posts👁️ 655 views
Posted Feb 18, 2010 · 22:31 UTC#1
I'm about to upgrade to 3.0 but want to backup "MyFlashdrive" before doing so. My unit currently has firmware 2.0 so I tried booting up with the version of Testmode for 2.0 (no issues there at all) but I when I copy the contents of "Myflashdrive" to my SD card files start copying for about a minute and then I get an error that says something very similar to:
unable to copy file "r" - Unable to read source file or disk.
Any ideas? I'm using a SanDisk 8gb SDHC card and have reformatted it twice (fat32 quick format and normal forat) renamed it a couple times (names with no spaces) but no luck. I know some say you cant use a card larger than 2gb but I have read many posts where people have used larger cards.
Any ideas?
Posted Feb 20, 2010 · 23:53 UTC#2
Tried 3 different SD memory cards (1 gig, 2 gig, 8 gig) and I get the same type of error each time.
unable to copy file "XXXXXX' - unable to read from source file or disk.
The name of file XXXXX changes every time I try a different card. I know I'm not alone with this error because I have come across others who have posted this same issue... but nobody seems to respond when the issue is posted.
