Mute button on map screen???
By Local399 · Feb 19, 2010in General💬 16 posts👁️ 3,026 views
Posted Feb 19, 2010 · 04:26 UTC#1
Hi all,
Just installed a Z110 in my 2007 Porsche Carrera. I am loving it! It works so much faster, smoother and just all around improved over my Z1 (with Z3 HD) in my 2004 VW Touareg.
OK, a quick question: On my Z1, there is a mute button on the map screen that I can be activated to mute the lady's voice and her turn by turn directions. I cannot find this button on the Z110. Does it not exist? And, if it doesn't, is there a work around?
As always, thank you all in advance,
Steve
Posted Feb 19, 2010 · 04:30 UTC#2
If you hold down the vc button it puts the whole system in mute. Don't know if this was what you were looking for. There is nothing on the screen.
Posted Feb 19, 2010 · 04:34 UTC#3
You can set a voice volume shortcut in the shortcut menu but there is no mute.
Posted Feb 19, 2010 · 04:42 UTC#4
And what will this do for me? Cant I just go there with a couple more steps? Or, is that the point?
Thanks,
Steve
PS: I just went out to my car and could NOT find anywhere to add this button on the shortcut screen. Please explain to me how to do this as it is not a given button option on the shortcut screen, thanks!
Posted Feb 19, 2010 · 05:10 UTC#5
You have to add it as a shortcut button in the settings. The shortcut menu is the bottom right button on the map screen.
Posted Feb 19, 2010 · 05:16 UTC#6
Excuse me for being dense...But, in what "settings" are you referring to? When you go to the shortcut menu screen (where you add or delete shortcut buttons), there is NO option to add any kind of volume button.
Please elaborate or, if possible, please tell me on what page of the owners manual this is explained.
Thank you,
Steve
PS: Again, I went to the car and there are NO options to add this button (volume) on the shortcut screen.
Posted Feb 19, 2010 · 05:24 UTC#7
My mistake, I meant to say QUICK ACCSES not SHORTCUT. Page 47 in the manual.
Posted Feb 19, 2010 · 05:39 UTC#8
Figured it out on my own!
There actually is a mute button for the voice, its just one screen in. Go to the quick access button on the map screen, hit volume and then there is a mute button for her voice on the volume screen.
Whew, glad that one got settled! I hate her voice for the most part. Is there a way to change it? My Tom Tom in my iPhone has that option. I so prefer the British ladies voice.
On a completely side note, found a great Porsche logo for the splash screen!
I am loving every aspect of the Z110 over my Z1, there is NO comparison! If I drove the Touareg more, I'd probably switch to the Z110 as well. Maybe one day...
Thanks again!
Steve
Posted Feb 19, 2010 · 05:44 UTC#9
In the VOLUME setting screen you can choose either TTS or nonTTS voice. The nonTTS voice is more natural but there is no voice with foreign accent.
Posted Feb 19, 2010 · 15:43 UTC#10
Ok, so I went to the "volume setting screen" and could not find any option to set TTS or Non TTS. Just options to set volumes, mute nav voice and turn off beep. Is there another Volume setting screen?
How do I get to this screen so I can change this option?
Again, thank you!
Steve
Posted Feb 19, 2010 · 15:53 UTC#11
Again, thank you!
Steve
It's in the regional settings... Check out about 2:00 in this video
Posted Feb 19, 2010 · 17:17 UTC#12
Yea my mistake again. This is all in the manual however.
Posted Feb 19, 2010 · 17:19 UTC#13
Couldn't find anything about this in the manual. Did a .pdf search for TTS and nothing came up.
Posted Feb 19, 2010 · 17:30 UTC#14
Try reading through the manual.
Posted Feb 19, 2010 · 17:40 UTC#15
Why would I read all 211 pages when I can just search on the .pdf version?
Hey, listen, you messed up twice in giving me information. Don't put that back on me!
Please, in the future, before you write something, make sure you know its correct. It will save everyone a whole lot of headaches!
Thank you,
Steve
Posted Feb 19, 2010 · 19:19 UTC#16
The questions you are asking can be answered by going through the settings of the unit or by reading the manual. I did use the wrong words in trying to answer your questions at a point when I was tired and just before going to bed. However I knew the answers because I happen to know how to use this unit by either going through the settings or reading the manual. You can do the same. We are here to answer questions for info that is not in the manual but not to baby sit people because they choose to not help themselves.
