POI Format
By jmontebian1 · Feb 19, 2010in Problems/Troubleshooting💬 5 posts👁️ 1,232 views
Posted Feb 19, 2010 · 13:24 UTC#1
Does anyone know what format you have to use to load POI's on your SD card for the avic to read? I have a customer list that is in excel and don't know if I copy that file if it will read it from the navi unit. Thanks in advance for any help...
Posted Feb 19, 2010 · 19:25 UTC#2
Well now that I know it is not excel any other suggestions.. I have added the Avic feeds to my laptop is this also something that should be added to my x910? I am reading the forums and looks like it only works well with the iphone. Is this true?
Posted Feb 19, 2010 · 20:12 UTC#3
The AVIC FEEDS PC app will work for the X series but I don't think you are going to be able to accomplish what you want. Your file must be in .CSV format. You will open that file with the AVIC FEEDS app and convert it to a KML file which will create POI files that you will then save to your SD card. From there you can put the SD card in the unit and browse the files from the unit. However, if the original files are not arranged in a POI style with GPS data in them this want do anything for you.
Posted Feb 19, 2010 · 21:40 UTC#4
Thanks I see what you are saying but on the avic feed does that program get installed into the head unit or is it just for PC use? I have my marketing team putting together a spreadsheet with longitude and lattitude points in it.
Posted Feb 19, 2010 · 22:24 UTC#5
PC only. The unit has an app that will allow you to access the POI on the SD CARD that are created with the PC app.
