Questions about N1 to CNDV-60MP conversion
By pass427 · Dec 06, 2006in General💬 4 posts👁️ 1,281 views
Posted Dec 06, 2006 · 18:22 UTC#1
Ok I was thinking of upgrading my N1 to use the CNDV-60mp dvds but I am concern about the ability to view movies while driving after the conversion. I have searched the board and there is a solution but i have not been able to find the definate answer on how to fix that problem once i do the upgrade. Can someone instruct me as the process of getting the video to play in motion once the upgrade is completed.
On a side note once I received the CNDV-60MP disc do I just put them in the N1 and let them do there stuff or is there a procedure.
Posted Dec 06, 2006 · 21:39 UTC#2
If you upgrade the 60mp disc you will lose the ability to watch movies and use some of the navi function while driving. Even though you grounded the wire with the first bypass. There's a way but it requires opening the head unit and soldering two points on the board. And as for upgrading the disc, just pop it in and it will upgrade itself.
Posted Dec 07, 2006 · 14:51 UTC#3
Ok thanks for the info, I have a buddy who is electronically savy but can I get the info on which two points on the board will need to be soldered. Thanks
Posted Dec 08, 2006 · 03:13 UTC#4
its in a different thread, just search!
