I seem to be having issue activating my MSN direct ....I get the product code and my HD reciever is working fine but it stays inactive. Is there any signal bars that I can see to make sure I am getting signal?? I am located in Atlanta so I know there is coverage...Any ideas ? signal bars ??
MSN Direct
No one knows if it has a signal level somewhere??
Yes, its in the MSN screen.
do you have a picture of it ...I dont see on mine
I am having the same exact problem.
I have a new Z110, and I receive FM radio just fine it seems.
I have tried having them send the activation code three times, and it still says "Inactive". I see absolutely no place where it shows signal strength.
My MSN serial key, which used to show on the status screen, is now missing, but it still shows "Inactive" and every button is greyed out....
What am I missing?
Thanks.
Your not going to see signal strength until you are active. You should call MSN Direct.
Jeez oh man. Pioneer, we need to see that signal for installation and activation troubleshooting.....
Thanks Vblue
The problem is not related to the unit. For whatever reason, your not getting signal from MSN. Like said, call them.
My issue has been resolved there is no signal meter at all that I can see but I had to drive closer to Atlanta to get it to activate now it works fine. Seems you have to have very strong signal for it to activate then weaker siganal for updates does not matter. If you are not seeing your code something may be wrong with you MSN tuner cause it needs to be connected to show code
I had the code, then it went away. I wrote it down, and MSN has it anyway.
I tried activation in what was supposed to be a strong signal area.
I will try again in a very strong signal area, but it would be nice to know where that is via a strength meter on the Z.
