D2 Turns Off After 5 Seconds Sometimes HELP!
By urbnlinx · Dec 06, 2006in Problems/Troubleshooting💬 13 posts👁️ 1,939 views
Posted Dec 06, 2006 · 19:16 UTC#1
purchased a new d2 installed by a "pro"
turned off 2 minutes after i left
unplugged left sitting for one hour and plugged it back in and it turns on
i broughtit back to the "pro" he checked out his wiring and said the d2 might be defective
so i returned it and got another d2 same wiring
just got it today
i connected everything everything was working , parked the car witin the half hour and it didnt want to turn on
now when im driving it turns on and offf,sometimes wont turn on sometimeswill
may i mention that this guy took out the 1k resistor from the red wire, wasthis the cause of this
any help would be appreciated as iv been stressin this system for close to 2 weeks
Posted Dec 06, 2006 · 19:54 UTC#2
I think they are fusible resistors. It'll work fine without it, because I bench tested one of mine that way when I didn't have a harness yet. Seems stupid to cut it off though, why would he do that?
Anyway, I find it unlikely 2 D2's had similar problems. I'd say it sounds like a wiring problem. Maybe a temperature related short or bad connection going open.
Posted Dec 06, 2006 · 20:37 UTC#3
What kind of car?
Posted Dec 06, 2006 · 20:52 UTC#4
300zx 1990
No factory bose
Posted Dec 06, 2006 · 21:02 UTC#5
Pull the ra't use the ground wire from the wiring harness. It's not dio and make sure the guy didn't use the ground wire from an aftermarket harness. There is no ground wire in the factory wire harness in that spot, so you MUST ground the radio ground wires to the chassis, not the harness. There is probably a ground point behind the radio on top of the tranny hump.
Posted Dec 06, 2006 · 21:03 UTC#6
Pull the radio and make sure the guy didn't use the ground wire from an aftermarket harness. There is no ground wire in the factory wire harness in that spot, so you MUST ground the radio ground wires to the chassis, not the harness. There is probably a ground point behind the radio on top of the tranny hump.
Posted Dec 06, 2006 · 21:20 UTC#7
whichones the ground
im not an audio guy im sorry
Posted Dec 06, 2006 · 22:12 UTC#8
The black wire coming from the radio harness, might be 2 of them. These should be attached to a secure ground, such as the bare metal that makes up the frame of the dash. The light green may also be attached to ground, if the installer did a video bypass for you, but that is a different story. Let's fix this first, OK?
Posted Dec 07, 2006 · 00:33 UTC#9
If it only works for a short ampunt of time then your installed definately grounded it in the aftermarket harness. In other words WRONG place. Pull it and ground it directly to one of the 500+ bolts sitting behind the dash.
Posted Dec 07, 2006 · 00:35 UTC#10
I went back to the guy , he tried a diff d2 it worked beautifully
Posted Dec 07, 2006 · 03:33 UTC#11
so that proved it aint the wiring , but I don't know what to do now, do I harass my installer or the seller or mayb there's something I'm missing
Posted Dec 08, 2006 · 15:06 UTC#12
If everything seems to be fine, be happy. Make sure the radio works properly when the lights are on, I've seen people use the illumination wire as a ground before.
Posted Dec 08, 2006 · 21:19 UTC#13
decided to harass the seller and make him get me another one
ugotadeal.com
the only reason i chose that place was because i work 6 blocks away
thanks for your help
