I have the x910bt and just wondering if I can disable the beep every time a button is pushed? I already turned it off in the nav but it's still on for everything else.
turning off the Key Beeps under NAVI SETTINGS - SOUND SETTINGS should turn off all the touch screen beeps as well as the steering wheel control beeps. however, when you do this, it will also turn off the "chime" you hear after pressing the voice command button. kind of stupid but thats the way it is.
what do you mean by "I already turned it off in the nav but it's still on for everything else." what is "everything else"?
Lame. I dont mind the beep..Just want to turn the Volume down a bit.
