Hi all
I've been an avid reader of this site since i got my F710BT.
I've spent days reading posts comments, trying to find someone else with the same problem as me and some sort of resolution, but i can't.
I've had the 710 for about 2 months working fine, about two weeks ago it would start to boot up and after about 7 secs (still on splash screen) it would go blank and the illiminated button would also turn off (does NOT reboot), i can still here the fan. No matter how many times i pressed the reset button it would not go back. Yes i've tried booting into testmode, but after about 15 secs it again goes blank.
If i leave the car for over 7-8 hours it will then boot up fine, but if i try to reboot i get the same issue as before until i leave it for 7-8 hours.
So leaving it 7-8 hours i managed to get into testmode;
I've flashed a backup from a f700bt, i've deleted those '4 files' on my flash disc and also the contents of the igo save folder as described on this site, none of which make a difference.
The reverse camera is switched off, the hardware & software bypass are fitted.
I've tried all the solutions i can find on here, the only thing i haven't tried is an installation of a different 710 EU backup, because i haven't got one.
All i can think is like some others have mentioned previously it may be a hardware issue.
Sorry it's a long one but wanted to fully explain, any advice greatly appreciated.
Thanks guys.
