Installing GEX-P5700TV Help!!!
By domdutch · Dec 07, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,501 views
Posted Dec 07, 2006 · 04:52 UTC#1
Guys im having trouble instaling my GEX-P5700TV with my Avic N2. I got a question, threw which cable does the power get supplyed to the GEX-P5700TV is it from the parking brake? Also the avic is grounded to the parking brake so do I have to also ground the GEX-P5700TV. And If any one can help out with any advice or hints becuase the instructions that came with it suck!!!
Posted Dec 07, 2006 · 23:03 UTC#2
If i remember correctly, the 5700tv gets hooked up to any 12v constant line. The IP bus will control it to turn on and off. The 5700tv does not need to be grounded.
Posted Dec 07, 2006 · 23:19 UTC#3
Ok my interpretation of the manual.
Yellow - Constant +12volts
Red - Don't connect to anything
Black - Ground
Green - Ground this if you want to be able to use it while moving. Otherwise hook it up to the parking brake wire in the car
So the unit DOES have to be grounded. Sorry PaisanNYC close but not quite.
Posted Dec 07, 2006 · 23:22 UTC#4
I have to check but i think my green wire is not connected.
Posted Dec 07, 2006 · 23:30 UTC#5
Well I don't know my info is based solely on reading the install manual. Either way the at least the black wire does have to be grounded for the unit to even work properly.
Posted Dec 07, 2006 · 23:47 UTC#6
you are right the black wire IS grounded for the negative. Im sorry. I was just thinking of the parking lead. Thats why I mentioned that. I forgot to include the black ground
Posted Dec 08, 2006 · 00:14 UTC#7
That's ok you're fogiven THIS time. Just don't let it happen EVER again. :lol:
Posted Dec 08, 2006 · 00:44 UTC#8
:::slinking back into dark corner::: :oops:
