back up camera quit working
By kdmann64 · Feb 27, 2010in Problems/Troubleshooting💬 3 posts👁️ 782 views
Posted Feb 27, 2010 · 12:16 UTC#1
Had to have a new bed side put on my truck due to a wreck. When I picked it up from the body shop they said the back up camera blew a fuse. Is there an inline fuse? I followed the wire from the camera to the dash, I didn't see one ,then it appears to go up to the d3, what could the problem be?
Posted Mar 18, 2010 · 16:28 UTC#2
most camera's do have a fuse, use a meter to check to see if there is voltage on the wires at the camera, also make sure that the reverse wire didnt get unhooked and that the setting is still turned on
Posted Mar 28, 2010 · 23:32 UTC#3
What camera are you using?
