6th Gen not recognized by 700BT....
By Wumpus · Mar 02, 2010in iPod/iPhone/iPad💬 7 posts👁️ 2,624 views
Posted Mar 02, 2010 · 22:14 UTC#1
What gives?
I have everything wired properly. I'm using the Pioneer Ipod cable designed for the AVICs. I tried using the Apple cable supplied with the Ipod also. Nothing is working.
I set AV1 to Ipod. I have parking brake and mute wire grounded for the bypass. I also moved the mute wire as per the bypass instructions.
Posted Mar 05, 2010 · 21:53 UTC#2
Seriously? No one has ever had this problem??
Posted Mar 05, 2010 · 22:00 UTC#3
Plug USB flash drive into the USB port with some music on it and see if the unit detects it. If it doesn't, you have a defective unit.
Posted Mar 06, 2010 · 21:36 UTC#4
Yeah that didn't work either. Is there any way I can send it to Pioneer to have them fix it? I bought it second hand I hope that's not an issue.
Posted Mar 07, 2010 · 01:02 UTC#5
Unless you have the original receipt showing you as the original owner, your out of warranty. It might be worth a try though.
Posted Mar 07, 2010 · 06:06 UTC#6
If I cant get this fixed then this headunit is completely useless to me. If Pioneer wont fix it is there any other way?
Posted Sep 05, 2010 · 20:11 UTC#7
Not that I am aware of.
