IP Bus - Must it be a loop?
By jobewan · Dec 07, 2006in General💬 3 posts👁️ 905 views
Posted Dec 07, 2006 · 16:50 UTC#1
Does the IP-bus always need to be hooked up as a loop? Must both in (black) anAND out (blue) wired be attached to the Z1 and then go around through the peripherals (i-pod & XM) ?
It appears that I am one bus wire wire short to do this so. I figured there'd be 2 long wires for the hideaway XM reciever which I've mounted under the driver's seat but there was only 1 long bus wire in the box. So, now I'm confused about how the bus works . Any 411 would be VERY helpful as I've almost completed the install.
Thank,
joe
Posted Dec 07, 2006 · 16:54 UTC#2
The Z1 has 2 IP Bus connectors? Every other Pioneer HU only has 1.
They hook up in a chain, not a loop.
Posted Dec 07, 2006 · 17:07 UTC#3
My bad, I mistook the AV-BUS from the tv-tuner for the IP bus. Thanks for clearing my head.
joe
