Finally iphone 3GS charged with AVIC F900BT!
By vampirello · Mar 04, 2010in General💬 4 posts👁️ 3,157 views
Posted Mar 04, 2010 · 23:07 UTC#1
Hello everyone!
Sorry for my bad English,I use a translator...
Finally I managed to charge my Iphone 3GS connected to Pioneer F900BT.
I have thoroughly studied the problem and I discovered that the 3GS performs an additional check on the terminal's USB connector.
The Usb protocol provides 4 connections:
Pin 1: +5 volts
Pin 2: D -
Pin 3: D +
Pin 4: GND
Match the connector Iphone :
Pin 23 : +5 volts
Pin 25 : D -
Pin 27 : D +
Pin 16 : GND
If you want that your charger (in this case our Avic) functions properly, you must be sure that the pin D-and D + respectively, there are 2.8 volts and 2.0 volts.
If the voltage is lower,the iphone display the message "accessory invalid .."
AVIC not provide these voltages correctly.
How to solve the problem?
The adapters that you can find in internet ( like Scosche Passport and other similar ) may not work because they are designed to reduce the voltage from 12 volts to 5 volts (firewire).
In our cable avic do not have the 12 volts to pin 19/20 of the dock connector, therefore, these adapters can never work.
Do not spend your money.
I thought of 2 solutions.
You could use the voltage of 5 volts present in the USB connector to get the 2 missing tensions, using the following scheme:
http://meletta.net/wp-content/uploads/2 ... schema.jpg
Resistors can be solded within the 30-pin connector that we use to connect our iPhone, but I have not tested to open it, to see if there is sufficient space.
Alternatively, as already written by other members, you can use a cable "Y" USB to connect simultaneously Avic + iphone + 12 to 5volt cigarette adapter.
I am using this system and it works perfectly.
This system works because the cigarette adapter is connected in parallel and provides the missing 2 tensions
Obviously you have to buy a cigarette adapter compatible with iPhone 3GS otherwise, the problem returns! ;-))
Even the Y-USB cable are not all equal, I have recovered 2 "Y" cable from external hard disks, but only 1 works.
Enjoy your Iphone !
Valerio from Italy
Posted Mar 13, 2010 · 16:41 UTC#2
Mine has always charged on my F90BT, never once had any issue what so ever.
Posted May 07, 2010 · 19:35 UTC#3
My old F700 used to charge my 3g, I just got an f90bt and it charged my 3gs the first time I plugged it in, but it no longer does :(
Posted May 08, 2010 · 13:15 UTC#4
I had a different solution to get the charging issue fixed!
The problem with the F series is that apple chip does not seem to allow both functions, charging and playing. With my F700, I found that it charges my 3GS no problem until it awakes and plays music, then it no longer charges.
MY SOLUTION
It was determined that the new X-series has the new apple chip that allows both functions of the iphone 3GS. I purchased the X910BT, use my F700 only for modding in my house (as this saves me running up and down to my car), and I have never been happier. The X series are now so cheap on ebay, that it was not even a costly affair
