Volume controlling stations?!?!
By krylon153 · Mar 05, 2010in Problems/Troubleshooting💬 9 posts👁️ 1,510 views
Posted Mar 05, 2010 · 16:15 UTC#1
I just bought and installed a avic-x710bt and everything went smooth except for 1 thing..... It seems that when am or fm is selected the volume knob starts the unit scanning through stations uncontrollably and the only way to stop it is to push the knob to the side. It does in fact turn the volume up/down as well but starts this scanning process at the same time even if the map is on and the fm/am is playing in the background. The volume knob works correctly in any other sources (ipod,cd). Should I reload the firmware from pioneer? I notice they have 3.0.2.1.0 on the site and my unit says 3.0.2.0.0.
A part of me hope to get flamed for asking such an easy question!? :)
Thanks in advance!
Posted Mar 06, 2010 · 00:24 UTC#2
Update - The update didnt fix it. Once I program the swi-pac Ill see if it still happens.....
Posted Mar 07, 2010 · 01:02 UTC#3
i have this same issue, i thought maybe it has something to to with the mods maybe? but it drives me crazy cause i always forget and i want to turn the volume down and my stations go crazy
Posted Mar 07, 2010 · 01:20 UTC#4
Well this is kinda good news as it makes me think its something fixable... I sure dont want to have to take it out after all that work!
Do you have a pac steering wheel control hooked up to it by any chance? Is it in a toyota? Maybe we can find some similarities in our setups which give us a hint....
Posted Mar 07, 2010 · 01:30 UTC#5
Also..
Did your do this before you did any mods? (mines stock firmware)
Is it bypassed?
Posted Mar 07, 2010 · 02:52 UTC#6
I fixed my problem.... I had my swi module hooked up to the HU but I didn't plug in the harness as I am waiting for some OEM phone steering wheel controls to arrive. I thought I would hook it up and see and sure enough it all works as its supposed to. Ill just have to reprogram the pac swi when I install my phone buttons on my steering wheel.
Hope this helps you with your problem!
Posted Mar 07, 2010 · 07:20 UTC#7
i actually did some work on my unit today, had to re-program the pac swi-ps...tomorrow morning i will re-check for the fm station/volume craziness
Posted Mar 09, 2010 · 22:01 UTC#8
ok i think i know what the problem was...im gonna blame it on the pac swi-ps....first of all do you have the pac?
i re-programmed mine all over again, and i connected it to a 12Vconstant(always on) wire....now when i shut off my truck the fm doesnt go crazy when i try to adjust the volume...
before, i used to have the wire hooked up to the accesorie wire so when i shut my vehicle down my stereo would beep and adjust the volume by a number or two all by itself then the fm tuner would go crazy when i tried adjusting the volume(Im thinking the pac would send a signal and confuse the avic)...so i came to the conclusion that the pac was getting tripped everytime i shut my vehicle down..so now its (always on) and i get no crazy volume/station changing...it worked for me
Posted Mar 11, 2010 · 03:19 UTC#9
Ya i have the PAC as well and Its defiantly is the cause of the tuner issue. Happy to hear you got it sorted! Mine however is connected to ACC and the problem disappeared I guess you just need to be a little cautious about the batt drain....
