GPS antenna extension?
By Dubbedown · Dec 07, 2006in General💬 6 posts👁️ 1,346 views
Posted Dec 07, 2006 · 21:20 UTC#1
Anyone know if Pioeneer sells some kind of extension cable for the GPS antenna?
Posted Dec 08, 2006 · 05:29 UTC#2
I don't beleive they do. How much longer do you need it to be?
Posted Dec 08, 2006 · 15:16 UTC#3
another few feet? dunno... i currently have it mounted on top of trunk, near center windshield but everytime i open/close trunk, see some of the wire sticking out of the trunk. i asked the installer if he could fix it but he said he had to loop it "that way" so that it would reach the trunk. if i wanted to hide the wire so it doesn't sneak out when i open/close trunk, he said i need some kind of extension to make cable longer
=T
Posted Dec 08, 2006 · 15:18 UTC#4
I'll check some stuff at work today and let ya know later tonight when I get home.
Posted Dec 08, 2006 · 15:51 UTC#5
appreciate it. i guess it doesn't have to be a pioneer, as long as it'd mate with the pioneer antenna.
Posted Dec 13, 2006 · 04:32 UTC#6
Sorry didn't get back to you sooner, lost the post. You can use antenna adapters to extend the gps antenna. The partnumbers are 40-eu10 and 40-eu20. You will need both and will have to slightly modify them to plug in. They will give you about 16 inches more length. if you need more you can get a standard antenna extension and use that between the 2 adapters. I wouldn't go crazy though after about 5 feet it started to affect the gps reception on my d1. Hope this helps you out.
