Z1 Stuck Disc/Screen Won't go Back UP
By hummer_h3 · Mar 06, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,070 views
Posted Mar 06, 2010 · 01:16 UTC#1
Insalled a new updated hard drive today in the Z1. Everything loaded up ok, and everything worked great. Went to load some customer screens and forgot that I had left a DVD in the machine. Pushed the eject button, makes a lot of noise, but no eject of the DVD.
Now, the screen won't go up, and the DVD won't eject.
Any way to manually eject the DVD? Hopefully, once ejected it might allow the screen to rise and the system to work again.
Posted Mar 06, 2010 · 02:21 UTC#2
IF possible, please delete. I was able to get the disc out with a small pair of needle nose pliers, hit the reset and all is ok.
Posted Mar 08, 2010 · 04:07 UTC#3
Did you try to put a new disc in to make sure the drive isn't broken?
You shouldn't have to pull them out with pliers :P
Posted Mar 09, 2010 · 01:18 UTC#4
As a matter of fact, I have recorded two discs to the hard drive since I removed that one disc. I believe it might have warped due to being in their for a long period in the desert heat. :mrgreen: I just tossed it when I pulled it so I can't really say it was warped.
