How do I know if VSS speed sensor connection is working?
By TopJimmy · Mar 06, 2010in Problems/Troubleshooting💬 2 posts👁️ 688 views
Posted Mar 06, 2010 · 01:44 UTC#1
I took my Nissan dash apart and connected the 910's VSS wire following these instructions.
http://www.clubfrontier.org/forums/f24/ ... all-34080/
The unit seems to work, MPH speed is pretty responsive on the setup/satellite screen, but I am not sure how much different it is from before the VSS connection.
Is there any way to confirm that the unit is getting the VSS signal? Is there a status indicator or something?
Thanks.
Posted Apr 07, 2010 · 21:15 UTC#2
According to the below thread, there should be some place on some screen of the display where it displays the signal/pulse that it's receiving from the vss wire:
viewtopic.php?f=58&t=30305&p=205346&hilit=vss+wire#p205346
Could be unit specific though...not sure.
Good Luck!
