Mac Hack
By Mr Nice Guy · Mar 07, 2010in Hacks/Mods💬 7 posts👁️ 3,105 views
Posted Mar 07, 2010 · 03:03 UTC#1
Has anyone done the software hack for the avic-x910bt on a Mac? If so what is the process for dummies?
Posted Mar 08, 2010 · 17:31 UTC#2
Yes. I do all of my stuff on the Mac through Parallels Desktop.
Posted Mar 10, 2010 · 01:50 UTC#3
I also did. However it is via fusion, running windows XP. Can you believe that? Windows in a Mac STILL runs better than just Windows. :o
Posted Mar 10, 2010 · 16:40 UTC#4
O'RLY?
Posted Mar 18, 2010 · 23:45 UTC#5
Did the hardware hack, it was fast and easy. I'll check out the software hack next.
Posted Aug 02, 2010 · 13:07 UTC#6
Mr. Nice Guy,
I see that no one has really answered your question. Saying that you did the software hack on a Mac running Parallels or Fusion isn't truly doing it on a Mac - you're still doing the hack in a Windows environment, which happens to run on a Mac. I'm a pure Mac user and avoid using a PC as much as I can (I don't personally own a PC). However, I can see people's reservations as this isn't a general computer help forum. I'm not going to give you a step-by-step on the Mac environment but I will tell you this, learning Macs is pretty intuitive. If you need to know what "Finder" is or where your user directory is located, there are a plethora of resources online that can tell you that. For the most part, the steps enumerated in the well-documented procedures on this forum can be done on the Mac. I did run into one problem, however, that may be of interest to you. It had to do with opening the pioneer.ini file in the DATA.ZIP archive WITHOUT extracting the archive. Most users were using WinZip or WinRar to do this, which don't run on a Mac. Please see this thread for instructions:
http://avic411.com/forum/viewtopic.php?p=225843#p225843
I hope this tidbit of information helps you or someone else reading this thread.
Joe
Posted Aug 02, 2010 · 18:30 UTC#7
Well Im with ya on not using a PC but I also know pretty much anything done on a PC can certainly be done on a Mac as well. In this case it was just a lot less time consuming to go ahead and do with Windows through emulation.
