SD card with AVI file movie on it...audio/video mis-sync
By BostonRobb · Mar 08, 2010in Problems/Troubleshooting💬 2 posts👁️ 856 views
Posted Mar 08, 2010 · 05:09 UTC#1
Hey all,
Odd issue here. I have a bit of a sync issue with SD card in my X7115bt.
I play the movie when in park (yeah I know I need to mod it but im a bit nervous) and it plays but it seems like the video is choppy along with the audio...a second off...as if it is buffering or something.
Anyhow. Has anyone else come into this issue?
Im a noob for sure with this unit so I am not going to be offended if someone points out an obvious fix on this.
MAP version 02.000409
Version 3.020100
thanks
-R
Posted Jan 09, 2011 · 04:05 UTC#2
I don't have that unit, but I would bet that the problem is due to a cheap SD card. SD cards come in several classes...I would suggest going minimum class 6. Yea, they cost a bit more, but totally worth it for the extra speed. Additionally, you may want to try re-encoding the video with a lower bit rate. There are numerous tools on the internet to encode videos. I personlly like the Xilisoft converters...they work pretty slick.
