Quick Question
By silveradoavic · Mar 12, 2010in Problems/Troubleshooting💬 4 posts👁️ 690 views
Posted Mar 12, 2010 · 16:55 UTC#1
Got the F900 unit installed last night using the Metra GMOS-04 harness.
Two issues:
My door chimes are very loud now. Where do i adjust the volume for this. is it the screw connected to the Metra GMOS-04 harness box itself. if so, i just thought that was a level adjuster for the music just like an adjuster on an amp to make it louder.
Also,
My DVD screen is now smaller than before. it has an inch of black on each side. i put in the same DVD as before the install and the screen was full and not cut off like it is now. Install issue or what??
Thanks in advance,
Posted Mar 12, 2010 · 18:33 UTC#2
the gmos 04 has two potentiometers for sound level adjustments (as shown on page 6 of the manual) the one at the top (next to the harness connector) is for audio level adjustment and the one on the side is for chime level adjustment
Posted Mar 12, 2010 · 19:31 UTC#3
ok cool :D
hope this is the last time i pull it out
probably not
still baffled about the darn DVD player screeen too
i will check the connections
thx
Posted Mar 13, 2010 · 22:11 UTC#4
dvd is fixed now too
sweet
