new owner, how do I...
By mcgilles · Mar 13, 2010in General💬 3 posts👁️ 847 views
Posted Mar 13, 2010 · 02:33 UTC#1
I'm on my second day of using my Z110 after a long extended installation process due to taking on a few other projects at the same time.
I can't seem to figure this out.
when I hit the mode button to go to the map screen it defaults to the version with the backup camera view in 75% of the screen and the map in the rightmost 25%. I don't think it was that way to begin with, I think I did this somehow by accident but I can't find the setting anywhere. I don't want it to default to the backupcam/map view, I want it to default to the map view. and how do I get back to the backup cam/map version when I do want it?
second my map view is locked in to the scroll mode. I can't figure out how to get it back to normal. the screen scrolls only when I drag my finger over it. it does not follow my current location, and I can't figure out how to get the map into 3D mode. where is the setting to do this? I'm going to do some searches through the manual pdf, but I read through the entire thing today (while I didn't have access to the unit to test things as I read) but I can't remember where the settings were.
thanks!
Posted Mar 13, 2010 · 10:57 UTC#2
1. Settings -> Map Settings -> Touch the type you want to set: [2D view], [3D view], [street View], [Rear View]. Sounds like you are currently on [rear view]. For more information, its on page 46 of the manual.
2. If its locked on scroll, I usually just touch the arrow on the upper left to set it back to regular mode. page 40.
good luck
Posted Mar 13, 2010 · 17:19 UTC#3
got it back to normal thanks! that's exactly what was happening. I was confusing the scroll mode with the map mode. I could only see the full map in scroll mode and when I hit the mode button or the arrow to go back it would return to cam/map which was not what I wanted, all because I had that setting set wrong for what I wanted, all back to normal now. thanks!
