help making the dimmer work correctly
By mcgilles · Mar 16, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,104 views
Posted Mar 16, 2010 · 00:36 UTC#1
I recently installed my Z110BT in my Corvette (99) and the dimmer does not work properly. I anticipated this because I've heard from other people with this setup that it doesn't work right. the screen dims opposite the instrument lights. the brighter I have the dimmer set the dimmer the screen gets and vice versa. in most GM cars you can also turn the dimmer all the way off and have the cluster lights off. I love this feature for night driving and using the hud to see important gauges. when you dim the car all the way though the screen goes into daytime mode and goes full bright. I guess it just doesn't understand the C5's dimer circuit. this is strange because I have aftermarket gauges in the car which are hooked up to this circuit also and they dim properly with the interior lights. how do I go about fixing the problem?
Posted Mar 16, 2010 · 00:52 UTC#2
The AVIC is looking for 12 volts when the lights are on (illumination), not a dimmer wire.
Posted Mar 19, 2010 · 02:21 UTC#3
hook up to a light wire for lighter ashtray, aftermarket gauge. it will not dim with gauges,but will dim for night view jim
Posted Mar 19, 2010 · 02:47 UTC#4
simple enough. the install manual didn't really explain that well. it looked like the unit would dim with the dimmer, its just backwards. but an all or nothing would work just fine. I have a perfect signal for it which I use for my digital gauges, 12V only when the headlights are on, but not with just the parking lights. that's the way I like it.
