LINCOLN LS VSS
By jhood2880 · Dec 08, 2006in Problems/Troubleshooting💬 6 posts👁️ 2,858 views
Posted Dec 08, 2006 · 17:21 UTC#1
Looking for help on locating the two wires to tap into for the vss on a 2000 lincoln LS V8.. I am hooking up the avic n3. Also i will need the same info for a 2001 chevy silverado 1500. We already have the units in we just dont know where to hook up the vss wiring!! Any help would be greatly appreciated!! thanks in advance!!
Posted Dec 08, 2006 · 21:59 UTC#2
The 01 Silverado should be a green/white in the radio harness, the Lincoln is white/black in the driver's kick. Happy hunting.
Posted Dec 11, 2006 · 14:43 UTC#3
Hey thanks i will let you know if i get it!!! :lol:
Posted Dec 19, 2006 · 06:43 UTC#4
my dads 2000 lincoln ls does not have a vss wire. i searched everywhere and even went under the vehicle at the transmission where some people have found it. but to no avail, its a computer data signal and nothing that can be hooked up to the avic. some of the 2000 models have it and some dont. you may need a pulse generator for the vss.
Posted Dec 20, 2006 · 01:36 UTC#5
Does anyone know the reverse wire and where it is located??
Posted Dec 20, 2006 · 01:55 UTC#6
In the Lincoln or the Silverado? Well, the Lincoln should be black/pink under the door sill, and the Silverado will be light green, either at the BCM below the steering column or at the junction box on the firewall in front of the driver's kick panel. Pull off the plastic cover, and it will be near the top in a plug.
