Installing x910bt in AUDI A4 2006
By nocturnalmm · Mar 18, 2010in Problems/Troubleshooting💬 6 posts👁️ 1,611 views
Posted Mar 18, 2010 · 23:28 UTC#1
Hey Guys, i am getting ready to install x910bt in my AUDI A4 2006. But have tons of questions as am a "Dummy". If you guys can help me with the following questions,
1) I am not using a rear camera- do i need to connect Reverse Signal Cable? If i dont connect will it affect the way GPS works?
2) How do i locate VSS lead in AUDI A4 2006? this one i have no idea at all. please help. Where is it located?
3) I am using http://www.audiworld.com/tech/elec164.shtml as my reference. Just want to be sure the pin-out diagram is accurate.
thanks a lot,
Posted Mar 19, 2010 · 15:47 UTC#2
thanks a lot,
1. Should not matter much, but why not connect it anyway, just in case you decide to add a camera later (very useful gizmo, really).
2. If it is like 2007 A3, which I believe it is, you need to get a CAN bus adapter. You need a CAN adapter to get to most of good stuff there anyway, so you may want to get one that does reverse, VSS, headlights at once (SoundGate, I believe, is what is used on mine).
Posted Mar 19, 2010 · 19:51 UTC#3
Hey BorisM, thanks for your reply. let me ask you another questions,
Do we really need to connect VSS?? Many post say it is not required
Posted Mar 19, 2010 · 21:22 UTC#4
It will work with no VSS connected, but it does help in tunnels and alike, when you have no GPS signal.
Posted Mar 19, 2010 · 23:09 UTC#5
I say leave the reverse wire not connected. Whenever you disconnect your battery or have to reset the AVIC, it will default the Rear Camera settings and you'll have to figure out how to get back in the change the setting. If it's not connected, then you don't have to worry about it. If you later decide to add a rear camera, then you can go back in and connect it.
Posted Mar 19, 2010 · 23:14 UTC#6
Thanks a lot guys. I have decided not to Connect VSS and Reverse cable. Will give it a shot and let you guys know. Thanks a ton.
