1996 toyota camry???
By apercele79 · Dec 08, 2006in General💬 14 posts👁️ 1,993 views
Posted Dec 08, 2006 · 19:28 UTC#1
i got me the D2, my sister wanted it
now my dad says he wants it, holy crap i should become a vendor
since my dad moved from queens to cali last week, it's safe to say HE NEEDS a nav system, he doesnt know his way around
just curious, would the D2 fit a 1996 camry? does anyone have the unit on? b/c if it doesnt fit, i would have to look at other brands....but to be honest, i prefer the d2 over all other brands....for 700-750 bucks, it's a steal
Posted Dec 08, 2006 · 19:54 UTC#2
Yes, it will fit fine.
Posted Dec 08, 2006 · 21:09 UTC#3
and simple install. real simple.
Posted Dec 08, 2006 · 21:20 UTC#4
Are you going to install this yourself? It's a reeeeeaaallly easy install.
Posted Dec 08, 2006 · 21:24 UTC#5
The only wires you won't find behind the radio are your VSS, which is purple/yellow at the ECM in the driver's side of the center console, and the reverse wire, which is red/black in the driver's kick panel. Grab a pizza and a six-pack and go to work.
Posted Dec 08, 2006 · 21:24 UTC#6
well, i did it on my a4 last month....on my sister's jetta this weekend and then my dad's camry in a couple of weeks :)
the a4 i didnt finish the job b/c i cou;dnt find the speed sensor so I gave up..it works fine without it
im guessing for the camry i would need the wire harness and dash din as well...?
Posted Dec 08, 2006 · 21:28 UTC#7
Use a run of the mill Toyota harness like the Metra 70-1761. Easy.
Posted Dec 08, 2006 · 21:30 UTC#8
sweet...thanks fellas
Posted Dec 08, 2006 · 21:32 UTC#9
As for the dash kit, not necessary. Just take the metal brackets off of the factory radio and pocket and bolt them right to the Z1. Just make sure you have a GOOD #2 phillips screwdriver. The screws in the factory radio are legendary for turning into cone-shaped holes if your screwdriver doesn't grab well, right cntry?
Posted Dec 08, 2006 · 21:33 UTC#10
im seeing there aint much of a price difference betweent the d1 and d2
actually on ebay the d1's go for 700 bucks, and i got the d2 for 750 bucks
i dont really know the difference between d1 and d2, but i might as well go for the D2 if the difference is only 50 bucks
Posted Dec 08, 2006 · 21:34 UTC#11
Posted Dec 08, 2006 · 21:35 UTC#12
Posted Dec 09, 2006 · 00:07 UTC#13
D2 has the updated maps! :) Best benefit for only $50 more. Pioneer charges $250 for the upgrade discs!!
Posted Dec 09, 2006 · 04:15 UTC#14
Man I love working on those camry's. Just so you know if the bolts on the factory radio strip you can use an 8mm socket to get them out. Odds are using a phillips screwdriver you'll strip at least one.
