what disk to use on D3?
By aznfunkyflip · Mar 19, 2010in General💬 9 posts👁️ 2,157 views
Posted Mar 19, 2010 · 17:19 UTC#1
HI guys, i just bought a D3 from ebay and didnt come with any disk. I've already downloaded the new cndv-90mt, but I'm not sure if I have to start with cndv-70mt or cndv-80mt.
The reason i'm asking is because i've read that the cndv-90mt is only an update. Does that mean i'll need to start with lower version because I start using the cndv-90mt?
Thanx in advance.
Posted Mar 20, 2010 · 03:41 UTC#2
hoping someone could give me some light here. i got the cndv80 and cdnv90 now. do i have to start from cndv70 after i install my D3?
Posted Mar 20, 2010 · 19:25 UTC#3
put in the 90mt and you are set
Posted Mar 21, 2010 · 01:55 UTC#4
so pretty much the files that are on 70 and 80 are already inside the cndv-90?
Posted Mar 21, 2010 · 15:20 UTC#5
If you are so unsured, why not just use the 70mt then use the 90mt for update. My bro was using the 70mt then updated to the 90mt. I have used all the discs and it ran the same as my bro. Like SWDW said, you aren't missing anything from the 80mt.
Posted Mar 21, 2010 · 17:27 UTC#6
i wouldn't even created this thread IF i have the 70mt disk. as i mentioned on my 1st post, i bought a unit from ebay that doesn't have a disk. :(
Posted Mar 25, 2010 · 20:04 UTC#8
Hello,
put in CNDV90MT DVDs and run!
The DVD flash the new firmware, you do not need to make a progressive firmware update (70->80->90).
Make sure to use a good DVD+R DL
Posted Mar 27, 2010 · 07:31 UTC#9
thank you for the replies guys.
