Freeway Signs
By best8845 · Mar 20, 2010in Hacks/Mods💬 5 posts👁️ 1,264 views
Posted Mar 20, 2010 · 04:46 UTC#1
I am dumb at working with codes or where should I start?
Is there a guide on what do I need to do to get highway signs to be smaller so it doesn't overlap the clock?
What file should I modify?
Right now, I am at stock 3.0 firmware.
Posted Mar 21, 2010 · 04:16 UTC#2
I would like to make them smaller too... I've looked though the code for the Highway Signs but can't understand the code... I've also looked through "Diaftia's" code from some of his data.zip's but I can't work it out!
It doesn't seem to be basic coding like I'm use to... I only know enough to add & change the on map buttons & move the clock around the screen...
Maybe "Diaftia's" or someone else will chime in & help us help ourselves???
PLEASE HELP,
Raymond
Posted Mar 22, 2010 · 20:41 UTC#3
You can add in a zoom= value to the signpost line in navigatemap_800_480.ui file. That will zoom in or out. Check my code for an example. Other thing you can do is go in and edit the laneinfo_signpost.ini file.
To simply adjust the width edit the w= value in the navigatemap_800_480.ui file. That will be the max width in pixels that it is allowed to be.
Posted Mar 22, 2010 · 21:52 UTC#4
There's also a how to thread somewhere in here. Search for "shrink" and you should get a few hits.
Posted Mar 23, 2010 · 06:44 UTC#5
Spent some time comparing and reading...
Got it done... still OEM-ish theme... just move and shrink the signpost...
Thanks guys.
