F900BT Starts up but keeps rebooting.
By Lcscl · Mar 21, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,301 views
Posted Mar 21, 2010 · 17:50 UTC#1
I've done plenty of research on this site and came to realize that i need to boot into safe mode. I downloaded and copied both MiTACAP and TESTMODE to my root on the SD car and when i turn on the machine it starts up normally, it does not boot into safe mode. I have the newest update version which is 2.008, could that be the reason why?? How can i get into safe mode to erase the gpspara files?
Posted Mar 21, 2010 · 22:17 UTC#2
nobody?
Posted Mar 23, 2010 · 12:19 UTC#3
Dood.
Go to this post: viewtopic.php?f=33&t=27155
I had the same problem where my unit would not boot off the SDCARD in testmode
You need to copy the WINCEIMG.BIN and WINCEIMG.CKS files from an SD card to your unit.
To do that you need to get your unit into service mode and do an SD Card Format.
Print off an carefully follow the instructions in the post above.
Posted Mar 23, 2010 · 12:24 UTC#4
BTW youve got the wrong testmode files. They are mentioned as corrupt. The one I used successfully is testmode_v2.3 It only has a "testmode" directory and no MiTACAP. Here: http://www.megaupload.com/?d=FXFEWLS0
It's a pain in the butt as it takes so long, but you have to carefully read and follow the instructions.
