Just had the AVIC-Z110BT installed
By tntsniper · Mar 21, 2010in General💬 3 posts👁️ 958 views
Posted Mar 21, 2010 · 18:25 UTC#1
Hey everyone!
I read a lot and I'm happy I chose to install the z110bt.. I have a couple questions and yes I did search and looked through the manual several times, pdf and paper lol.
I had an installer install my navi.. I had to have them do it as I have no time at all (Traveling and working 60+hours a week).
They installed my iPod cable fine, but I don't see a USB Cable so I can plug in my flash drive? They said once you install the Ipod Cable you wont have access to the USB Cable, is this true?
Second question, They mounted the GPS and SIrius antennas in the back windshield of my car. I notice that its working fine, but I look at the signal and its pretty low (Bar wise).. Is this a good or bad thing? Has anyone else mounted the antennas under the back windshield? My sirius has skipped a couple times, I'm wondering if its due to lack of signal?
One more, (this one I probably could search for, which I will, but it just popped in my mind now), My z110bt was made in Sept 2009. Do you think there's an update for it? So far everything is working great, no issues :)
Posted Mar 21, 2010 · 18:33 UTC#2
The ipod cable plugs into the USB extension.
Sirius works best outside the car. It doesn't matter much for the GPS antenna, but it works best when stuck to something metal
There are no upgrades/updates yet. You should be able to buy the next one off Pioneers site in a few months
Posted Mar 21, 2010 · 20:02 UTC#3
The ipod cable can be unplugged and a USB drive used but it is either or. Their wording that once the iPod cable is plugged in you cant use the USB connection is not worded correctly. Swapping back and forth between iPod and USB drive will be no problem.
