AVH-P4200DVD Bypass Wiring
By IrishPilot · Mar 22, 2010in General💬 3 posts👁️ 6,227 views
Posted Mar 22, 2010 · 23:37 UTC#1
Been watching this...
And I have this...
http://cgi.ebay.com/PIONEER-DVD-BRAKE-BYPASS-HACK-AVH-P5200BT-AVH-P5200DVD_W0QQitemZ130369230584QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e5a9c96f8#ht_717wt_1165
and have been trying to figure out how to get it all set up properly. Im trying to have it all down in my head before I go tearing the HU out to get at the wiring.
My questions are...
[*]Is it necessary to disconnect the battery first?
[*]What changes if I have amps hooked up? Anything?
The directions on the bypass say to...
[*]hook the blue wire to the remote turn on wire on Pioneer HU (blue with white)
[*]hook the black wire to ground wire on Pioneer HU (black)
[*]hook the green wire to the brake wire on Pioneer HU (light green)
The headunit is already installed, so what do I do with the current connections? I would assume the remote turn on wire is currently connected to a wire running the amps etc. right? So do I just disconnect it and ONLY connect the relay and the remote turn on wire on the HU? Wont that eliminate the amp turn on?
As you can tell, I did not do the HU install myself but would like to get this relay setup. Any insight or direction would be greatly appreciated. Thanks!
Posted May 10, 2010 · 23:20 UTC#2
check out www.avhbypass.com
Posted May 12, 2010 · 00:57 UTC#3
The blue/white wire (REMOTE TURN ON) on the head unit needs to power up the by-pass relay as well as turn on the aftermarket amps.
